Trany mount replacement causing vibrations.
Old Feb 11, 2008 | 10:25 PM
osvaldo's Avatar
Default Trany mount replacement causing vibrations.
I changed my trany mount cause the old one was worn out. I had a polyurathane and i replaced it with a poly as well. But now there is a weird vibration when i'm turning the car on and it gets even worse as the rpms get high. Any ideas? I was thinking maybe the engine mount needs to be changed now. Or the mechanic didnt put the trany mount on right. Either way i will take it back tomorrow I just thought someone might have an idea. Thanks
Old Feb 13, 2008 | 03:16 AM
insanez's Avatar
Psst... You just found out your motor mounts are worn out too...this happened to me and a buddy, new motor mounts in, vibration out.
Old Feb 13, 2008 | 08:35 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
It's pretty common for people to complain about additional noise after installing the poly transmission mount. There is not much you can do about it unless the motor mounts are bad even then it's still going to be noisey.
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old Feb 15, 2008 | 04:01 AM
1QUIKWS6's Avatar
Exactly^^^^^^^^^^^^^
I'm constantly suprised when people run out and replace their stock rubber tranny mount and engine mounts with Poly versions and then complain about the vibration - what did you think would happen?
Most of the time the poly mounts aren't even needed - they just install because others are doing it. I still have the stock ORIGINAL factory tranny/motor mounts in my TA with the HP/TQ in my sig and no problems - no vibration either.
Less deflection=more vibration/noise imparted thru out car
You can't have a stiffer handling car and expect it to ride like a caddy...
Same thing goes for those that complain about noise/vibration after installing the Spohn Tq Arm that utilizes a lever style poly front mount vs the sliding rubber bushing stock front mount.
There is always a trade-off somewhere when installing performance parts. That is why factory uses rubber instead of poly - because the normal buyer would complain about noise/vibration and report that the car is a POS
