LCAs - Making them
Old Feb 13, 2008 | 01:28 AM
JayErnie's Avatar
Default LCAs - Making them
Hey people,
Looking to mod out the rear end suspension/stabilisation for a better handling, i.e. less rear-end swing when you take a bump in turn and stiffer response. I know we don't have a full-independant suspension out there, but there is surely a way to make that rear-end more track-stable competitive.
I know there is a thread somewhere about making LCAs, I had read it in the past and it was very clear, all detailed with pictures and, but I can't manage to find it back. Anyone got a clue where it's at?
The car is gonna have a full set of Poly bushings soon, but taht's not gonna enough. Once it is gonna be lowered, it'll have an adjustable panhard rod too. So basically, the rear sway bars and that panhard-rod are gonna have poly bushings, nothing else though. So I was thinking of making the LCAs myself and maybe the panhard-bar too, in order to take out that poly-bushing and fit at the end a metal bushing (alu, brass or something else harder), or a rod end, w/e is gonna be the most reliable. My dad used to make out his own Control-arms on his track cars without bushing, directly metal on metal, and used to fit grease nipples on the end, just to grease the swivel parts and ease-out the friction. Pretty rough, but sturdy and stable as hell, and no comfort, but at that point, it doesn't matter.
Any advices, ideas anyone?
Old Feb 13, 2008 | 02:12 AM
mrhzk35404's Avatar
You are better off just buying them from UMI or someone else. They are not that expensive.
Old Feb 13, 2008 | 07:52 AM
mitchntx's Avatar
REAR LCAs -
2 16" aluminum trailing arms - $32
http://www.colemanracing.com/catalog...oducts_id=2957
4 QA1 XM rod ends (2 left hand thread and 2 right hand thread) - $120
http://www.jegs.com/webapp/wcs/store...10002_71378_-1
8 Herron Performance spacers - $40
http://www.frrax.com/rrforum/index.php?showtopic=10589
PHB -
1 39.5" aluminum trailing arm - $21
http://www.colemanracing.com/catalog...oducts_id=9297
2 QA1 XM rod ends (1 left hand thread and 1 right hand thread) - $60
4 Herron Performance spacers - $20
6 QA1 XM jm nuts (3 left hand thread and 3 right hand thread) - $14
http://www.jegs.com/webapp/wcs/store...10002_72948_-1
http://www.jegs.com/webapp/wcs/store...10002_72946_-1
Grand total ... $307
Old Feb 13, 2008 | 08:18 AM
DropTopBird's Avatar
Wow thats more than what I paid for mine shipped. Id just pick up a set unless youre dead set on making them yourself.
Old Feb 13, 2008 | 08:52 AM
JayErnie's Avatar
That's sweet, thanks alot mitch for that quick display there. And Drop, I beleive that 307bucks for all rear LCAs and a PHB , all adjustable, isn't very expensive IMO. I'll look into that.
Old Feb 13, 2008 | 09:02 AM
91_RS_LS1's Avatar
You can get some rubber ends and save some green. They will make for a better ride and won't wear out like the rod ends with little compromise in performance. They used to be sold be lefthanderchassis, but their site seems to be down.
BTW, I've read that QA1 has moved their manufacture to China and the rod end quality has suffered. Might want to look into these rod ends. JMXT-12
BTW2, you can get jamb nuts from Coleman for about $.85 for the right hand thread and $1.00 for the left.
Old Feb 13, 2008 | 12:22 PM
87formy's Avatar
Originally Posted by mitchntx
REAR LCAs -
PHB -
Seems like a lot considering you can get them made by SJM manufacturing for 330 IIRC, forget what the other companies charge, but it hardly seems worth the effort IMO.
Old Feb 13, 2008 | 01:05 PM
mitchntx's Avatar
http://www.sjmmanufacturing.com/cam_...0Control%20Arm
$360 and they are tig welded steel, not machined, billet aluminum.
SJM has a great price and have quality rpoducts. But let's compare apples to apples.
Also, the original poster asked about DIY parts, not necessarily where to buy things the cheapest.
Old Feb 13, 2008 | 05:54 PM
SJM Manufacturing Inc's Avatar
Thank you for the nice comments Mitch.
Just to clarify, they are 329.99 in the special section for both the LCA/PHR combo using rod-ended components.
http://www.sjmmanufacturing.com/deals.html
Also to clarify, aluminum components can have its benefits, if you do a quick analysis on the difference in deflection between the typical 1.25x.095" and typical aluminum setups, one should find the aluminum pieces actually deflect to a higher degree during axial loading (only stress seen). Shock loading will effect material different as well.
This is a question by the original poster regarding a DIY mod...this on itself can be gratifying so price may not be main concern... Typically when I see folks looking for a DIY setup though, it's an assumption they are probably trying to do it for saving money. Nothing replaces the self gratifying feeling of designing and building their own components.
Good luck!
Old Feb 13, 2008 | 07:01 PM
mitchntx's Avatar
I didn't see the "deals" section ... even better price.
FWIW ... I've been running the above components for 3 years on my road race Trans AM. Lou Gigliotti runs them on his Trans AM GT Corvette.
They're plenty strong.
Old Feb 13, 2008 | 07:47 PM
JayErnie's Avatar
How was it on the handling and how was the wearing on the rod ends actually?
