welding sub frame connectors
What are you refering to as "tank" welding? I welded mine in with a 125 mig with some 030 solid core wire and i use gas if thats what you mean because of the solid core wire. But you could weld em with a mig and flux wire without gas
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
you want to use mig welding..clean the surface with a sander. argon or flux type is fine.....also electric or stick type welding is fine. flux coated rods like contractors use. tank or gas or atcetlene type with a torch shoul not be used. to much heat spread.............RON..........THE WELDER
