Need rotor advice
I'm planning on doing a little brake job friday/this weekend... Hopefully a light turn and some pads will clear everything up..
Once the stock rotors warp, they are gone. You can have them turned, but they are going to warp again pretty fast. If your rotors are warped now, talk to us again 10k miles after you have them turned, and we will see if I'm right.
I agree with this.
It's really the runout from uneven material padding on the rotors that can be corrected through resurfacing. If the rotor truly warps, then it's next to impossible to correct through resurfacing.
We can get the PowerStop Cryo treated rotors however I would have to order them for you!
Had great luck with the ATE's and in fact based on cost and the extra's (like the coating) and the fact Brembo keeps moving their plants to various countries I'm recommending the ATE over Brembo most of the time these days. www.stranoparts.com --814-849-3450
