Weld in SFC question
Old Feb 28, 2008 | 02:47 AM
iceman15's Avatar
Default Weld in SFC question
So I ordered some weld in Umi SFC but today while I was under my car I noticed that the front ears or horns that the SFC will wild onto is not a flat surface. They look indented alot, like the previous owner had jacked it up from that location but had put some dents in there and left it smashed in on some portions. Any way to fix this dilemma? or would it effect the SFC when they get welded in??
Old Feb 28, 2008 | 11:11 AM
Dskeet6's Avatar
yea that sounds like a problem..... call and ask UMI someone might have to weld a bolt on there and pull them back down slightly
Old Feb 28, 2008 | 12:05 PM
iceman15's Avatar
yea thats what i was thinking as well, maybe the bolt in would suck it back down and level it out. I will give them a call. Thanks
Old Feb 28, 2008 | 12:08 PM
iceman15's Avatar
One more question, does the suspension have to be loaded when you weld in SFC? Of can you use a tuck lift and just let the tires hang down?
Old Feb 28, 2008 | 01:35 PM
SOMbitch's Avatar
Loaded on level surface.
Old Feb 28, 2008 | 02:56 PM
UMI Performance's Avatar
Yep, loaded and level.
If you need any help or have any questions that the installation instructions do not mention please give us a call and we will be glad to assist you.
Thank you!
Ryan
Old Feb 28, 2008 | 08:55 PM
iceman15's Avatar
Thanks Ryan I will be sure to give you a call if I have a question
-George
Old Feb 28, 2008 | 10:27 PM
01ssreda4's Avatar
mine were slightly bent also. i used a little extra weld to fill in the gaps.
Old Feb 28, 2008 | 10:36 PM
iceman15's Avatar
Oh ok so they welders were able to just put some extra weld without any problems??
