Adjusting my Konis.... adjust while suspension unloaded or no?
As it says.... can I jack the front end up to adjust my Konis or does the suspension need to be loaded (on the ground)?
Same with the rears?
Thanks!
Thanks!
I adjust my fronts by jacking up the front and reaching my arm between the wheel and fender well (after the car is on jackstands, of course). I have 4th gen rears, so the **** is on top of the shock, meaning I don't have to jack up the rear to adjust them.
-Mike
-Mike
Thanks guys. Much appreciated.
For some reason I thought I had to adjust the fronts with the suspension loaded... which would be a major PITA.
I have the 4th gen rear too... piece of cake to adjust.
Thanks again.
Thanks again.
