Looking for recommendations installing suspension kit
BTW, I have a 2002 camaro SS with the SLP exhaust and wheels
In general be sure to work safely, jack stands, etc. and take your time.
Be prepared to do battle with front shocks - especially the right front, getting the top bolt off can be a challenge.
Use a good spring compressor and follow the safety precautions or have someone mount the springs on the shocks for you.
the left front shock requires removal of the master cylinder from the mount and moving out of the way take your time and be careful.
The rear springs come right out after you disconnect the shocks and lower the axle. Make sure you get the rubber mount and put it back properly.
Do your homework and get all the torque specs before you start.
tighten the LCAs after you put the weight back on the rear - and follow the torque specs.
Find a good alignment shop and make an appointment now to have it aligned when you're done.
What kind of LCAs are they? The phr is adjustable right? I would also get some relocation brackets because you're car is going to be lower. These will allow the LCAs to be parallel with the ground again.
