suspension guys com in
i recently bought
lcs's
panhard
strut bar
sfc's
and thinking about adding a 6pt cage too
will there be a noticeable diff in the way it drives and hooks up???
Certain mods can help you in one application and have an adverse effect on the other. Like LCA relocation brackets for example can help you with your straight line traction. They change the angle of your control arms. Helps you put down power at that angle, but in turns will point your axle slightly away from the direction you are turning. I don't know how significant it is myself, but Sam says it's significant enough to hurt your ability to keep the car under control.
I may experiment with the bolt on LCA brackets myself because my racing application contains both launching and turning
I see that list of stuff, and I don't see shocks. And, as anyone here who's been able to compare before/after can attest, they make a HUGE difference in how the car drives. So much so they are what I start with even if stock springs stay in place. And lowering springs demand better damping that much more.
I think it's pretty obvious I sell shocks, but I also sell LCA brackets, TA's and all the rest of the stuff too. Shocks are in dire need here. Koni's are best, but at this point even something lesser would help (going by the fact the car has been on stock shocks and lowering springs for at least 4 years, and obviously on stock shocks even longer since the cars haven't been built in almost 6 years now).
There are guys cutting 1.5 60 times on Konis. You need shocks, good ones. You will KICK YOURSELF IN THE NUTS for not doing them first. Ask me how I know...
IMO Chevy should upgraded the Z28 factory shocks from the get go. They are awful. Stock for stock my freaking dodge intrepid was more stable at 100mph than the camaro. Now with the shocks the camaro is solid at all speeds right up to the govenor.
