rear suspension ?
Old Mar 19, 2008 | 07:10 PM
devildogws6's Avatar
Default rear suspension ?
so im putting on 315s in the back i have the sportline springs and wondering how to get about a 1/2 inch lift in the back to clear the tire or do you think i could get away with fender rolling and pounding in the inner wells here is a pic for reff The tires and rims in the pic are the old ones i have TTII on the way 17*11 in the rear with some nittos 315
Old Mar 19, 2008 | 07:26 PM
zach_ws6's Avatar
yep, they will definitely rub as it sits now. well first try rolling the inner fender well lip. it may be all you need to do. i wouldnt beat on it though, just cause that is good way to crack your paint.
if you still have your stock springs, you could cut a coil off of them and put them back in your car
Old Mar 20, 2008 | 06:16 AM
i dont have the stock springs is there springs out there that i could get that would help
Old Mar 20, 2008 | 06:54 AM
SSWS6's Avatar
Get some BMR's they only lower 1" which is why I got them. Have 315s also and no rubbing so far.
Old Mar 20, 2008 | 07:20 PM
Thanks for the help ill try rolling the fender then if need be get the bmr springs
