What wires to ground to get rid of abs light...
Ok. so i know i read it on hear a couple weeks ago.
I believe it was wire 8 and wire 13 needed to be grounded to get rid of abs light, but i think it only worked on 98's as those wires on newer ls1's were not there.
Does anyone know if it is wires 8 and 13 on 98's?
If not will pulling the fuses get rid of dash light, or does it have to be taped over or pulling the bulb.
I just did the sjm abs delete kit and linelock, and just want to get rid of the light.
I tried searching for over an hour tonight, and could not find it again.
Thanks in advance, Chris
Well if we figure out what we have to do for sure, other then putting tape over led, or pulling the led it should maybe be added to the faq so it can be easily found.
Thanks, i will try some things out the next time i work on my car.
Chris
Chris
Ok, for anyone wondering. On a 98..
pin 7 to pin 12 turns the ABS INOP light off.
pin 16 to pin 12 turns the BRAKE light off.
Info came from steve @ SJM. I have not tried it yet, but thanks Steve!
Chris
Chris
