Spohn T/A Broke!!!
Old Mar 25, 2008 | 03:24 AM
SIC LSX's Avatar
Default Spohn T/A Broke!!!
This is off of my friend DD street car on street tire. He said he got on it and heard a pop so we checked it out and it was this.
Can the rear section be replaced???
Old Mar 25, 2008 | 03:36 AM
97badass's Avatar
i say hit spohn up and talk to them.
Old Mar 25, 2008 | 03:48 AM
jessedale98's Avatar
I say never let your friend drive again.
Old Mar 25, 2008 | 04:11 AM
SIC LSX's Avatar
lol he no's what he is doing. He has a 400+hp ls1 T/A that the torq arm broke on and 540whp Lt1 T/A. The yare both m6 cars. He built his lt1 T/A and everything that is on the silver T/A was on it when he got it! The Torq arm was bolted to a moser 12 both too.
Old Mar 25, 2008 | 04:53 AM
Black FormulaLs1's Avatar
whoah wtf....i would call spohn and see whats up...
Old Mar 25, 2008 | 07:20 AM
UMI Performance's Avatar
Moser 12-Bolts are known for that, the bolts on the bottom come loose and cause the torque arm to shift making it crack. If you a do search you will find this is very common on the Moser 12-Bolt, so common us and including other suspension companies void warranties when running the Moser 12. This is all do to Moser's design of bolting the bolts up from the bottom, they are short small bolts and tend to work loose.
Go to Spohn's site and buy a new bracket for $50. But in order to prevent this again I suggest to tack weld the bolts to the bracket.
Hope that helps,
Ryan
Old Mar 25, 2008 | 10:24 AM
ks my ss's Avatar
Hope that helps,
Ryan
i think 2 bolts were missing and 2 were loose
Old Mar 25, 2008 | 12:37 PM
revtime's Avatar
Not Spohns fault, it's Moser's.
Unbelievably bad design on those rear ends. The fact that they have not manned up and redesigned that mount says alot.
Really, the fact that bolting your aftermarket TA to Moser's rear voids your TA warranty..........that should be the dealbreaker right there.
Old Mar 25, 2008 | 12:46 PM
SSstud's Avatar
yea thats too bad...regardless to the rearend it was bolted that shouldnt happen. that doesnt give me a good impression of spohn
Old Mar 25, 2008 | 01:05 PM
chevroletfreak's Avatar
Just use safety wire on the bolts. They will not come loose unexpectedly and you will be able to remove them when needed unlike a tack weld.
Old Mar 25, 2008 | 01:07 PM
James Montigny's Avatar
I think you would have had the same problem with BMR or UMI.
Having those bolts gone is a lot of pressure to put on any arm.
Old Mar 25, 2008 | 01:19 PM
LS1crazy01's Avatar
Yup X2 I never heard of one breaking on a 9 inch.
Wonderbread's Avatar
Did you not read the posts above? No matter what brand T/A this would happen. You have to check those damn bolts almost weekly. If you don't this will happen. I run a Spohn on with a 9" and have no problems.
Old Mar 25, 2008 | 02:05 PM
SIC LSX's Avatar
yeah we dont like the moser 12 bolt at all! His other car has a stange and loves it. It still uses the 2 long bolts not the short ones. Who even install the T/A and 12 bolt did not use loctite and the 2 top bolts were gone and the botton ones were losse. This is not spohn's falt. We were just wanting to no if we can get a new rear section for it?
Old Mar 25, 2008 | 03:55 PM
JScamaro's Avatar
I don't plan on getting a Moser 12 bolt for this very reason.
Old Mar 25, 2008 | 03:58 PM
Black02SLPSS's Avatar
This is why everyone needs a little strange rear.
Old Mar 25, 2008 | 04:29 PM
SSstud's Avatar
haha whoops yea sorry im an idiot i dint catch the most important part about the two missing bolts...i take back what i said and deem myself a moron.
Old Mar 25, 2008 | 04:33 PM
omcar's Avatar
I agree..give Steve at Spohn a call he is a good guy and should take care of you.
Old Mar 25, 2008 | 04:51 PM
OutlawZ's Avatar
Exactly why I've had my Moser 9 inch (IE the king of rearends) sitting under my car for close to 9 years without so much as a whimper.... it's taken so much punishment and i've never had an issue. meanwhile my friends have been thru multiple 12 bolts or T/A's in that timeframe.... don't even get me started on the KTRE 12 bolt group purchase for anybody that is REAL OLD SCHOOL.....
Old Mar 25, 2008 | 05:10 PM
SIC LSX's Avatar
Well this moser 12bolt has had 3 sets of different gears and it also wines now mater what has been done to it from what i have been told. His strange 12bolt is quiet and never had any problems. He hates everything about the moser and loves his strange.
