Brake Pad Clip??
Old 07-26-2003, 03:31 AM
CrewRacerSS's Avatar
Default Brake Pad Clip??
Hey all you brake experts out there, the clip that holds the pad in the bracket is rubbing my caliper for whatever reason , my question is can i remove those two clips and be cool? The fit doesn't seem that different with them in or out. TIA
Jeff
Old 07-26-2003, 10:43 AM
mitchntx's Avatar
Default Re: Brake Pad Clip??
No, those "clips" (the brass looking, smooth metal guys the fit into the tops and bottom of the abutment bracket) are needed to give your brake pads a smooth path on which to move.
Try swapping the to ends or the sides ...
Old 07-26-2003, 11:34 AM
Freak's Avatar
good rule of thumb with brakes: NEVER leave off stuff the factory put on. its there for a reason, even though it might not be apparent to you.
