got the rear shocks and springs installed...
well i followed the ls1howto write up ...installed koni shocks and pro kit... well after i got the new shocks put on there was no way i could put the springs on so i un bolted the shocks put the springs on , i had to lift the rear a bit with a jack to be able to put the shocks on again. after i put everything else back on i put her on the ground and looks like i did everything right. took the car for a drive and everything seemed ok. only problem is that the drivers side seems to be a bit higher than the passengers by 1/4 of an inch.. have any of you noticed this ? or did i do something wrong??
i havent installed the fronts yet...
After just coming off a Koni/Strano install today here is what i've learned.
A. Have plenty of WD-40 on hand
B. Don't waste your time trying to reuse the upper shock mount in the front. Go buy new ones from your local parts house.
C. If b is not a option prepare to cuss beat and bang. Also have a torch, sawzall, cutoff wheel, and a impact handy.
My car seems to have a 1/4 of lean aswell.
