nut and bolt size for TA mount and shocks
I'm taking my rear out and I do not have big enough sockets, wrenches for the shock nut and the TA bolts and nuts. what size are they??? they are both stock so they are factory.
Re: nut and bolt size for TA mount and shocks
OEM TA-to-axle housing bolts/nuts are 21mm. I'm using Bilstein shocks and I think they came with their own nuts in the rear (really can't remember, but they don't look stock). I use a 7/8" on those, but that's a little loose - I'm guessing they're metric as well - probably 22mm... not sure if that helps beyond recommending you purchase a handful of larger metric sockets/wrenches
