Grade 8 bolts for endlinks
Is their a place I can buy Grade 8 bolts in bulk for my swaybar endlinks? My BMR 21mm swaybar has bent 4 of them now in 6 months. Rather than buy the hole endlinks and bushings I'd rather buy like 10 bolts. Anyone know of a place I can order these?
Re: Grade 8 bolts for endlinks
Good luck!
Well you can get Grade 8 bolts at NAPA.
But like trackbird says why are they bending.
If your not gonna to answer that maybe you should get 20.
These should experience tensile or compression forces.
I think the problem should be addressed and not the symptom.
Chances are good, that if you are finding enough force to bend these bolts, especially inside a sleeve, you are gonna just bend or break the next weakest link, like the ear on the frame.
Why they are bending I have no idea. I have a new set on their for now. I'll see how long they last. I have a road race session at Gateway coming up soon. I guess I'll see how they are doing after the race. I do push it very hard when I take it out on the weekends though. It deffinatly takes some abuse on the backroads.
I had two of the rear bar bolts bend. They had about 1 inch of displacement from end to end. I went to Energy Suspension endlinks and they haven't bent yet (SLP 1LE 21 mm rear bar on 99 SS), about 4 months in service. The Energy Suspension endlink bolts are larger in diameter, looked like going from 3/8 to 7/16 inch diameter, but I didn't get out a caliper and measure them.
