Need Help Picking Out Front Suspension - Iron Block 408
Ok fellas, I know it's a long time over due but I need some help choosing which aftermarket front suspension components to go with. This car is driven on the street, but I can sacrifice some streetability for performance at the track if need be. I do have 9inch w/ spool and True Duals dumped...
The problem that I am facing is at the track after launching when going into second gear my car sometimes nose dives and scrapes my front bumper on the track (I have a 6speed). Somehow my oil filter even came lose one time. Let me also note that I don't have any weight reduction done and everything is stock on the front suspension. I do have my front sway bar removed.
Temporarily I am thinking about purchasing 4 BMR spacers to put 2 on each side. That would give me an extra inch of clearance. Any thoughts on this?
What if I just replaced my front springs with QA1 325lb springs? Would this help with the front traveling so far back down and scraping the ground? What springs would you recommend?
If I bought adjustable shocks, would single adjustables be good enough or do you think I need double adjustable? What is the difference in the two?
ANY help is greatly appreciated!!!
TIA!
- Rusty
TIA!
- Rusty
LS1Tech Premium Sponsor
TIA!
- Rusty
TIA!
- Rusty
Thank you for replying!
Will the Single Adjustable QA1 Drag Race "R" allow the front of my car to settle down slower? Doubles are $$$.
When you said you would look into a stiffer set of springs did you mean stiffer than 325lb?
Is the stock springs stiffer than 325lb? How does it compare to the 325lb spring?
Thanks Again!!
- Rusty
Thanks Again!!
- Rusty
Pa Racing
I got a forged 6.0 in my camaro with a APS TT and jason at PA Racing sold me a set of AFCO front springs rated at 350 and a set of strange single adjustable shocks that are pre rated meaning no need to set the pull and push of the shock like Q1As do ! He said it would be a waste of money for me to invest in the dual setting shocks in the front unless i was all out road racing or strickly track.This is what he told me !Do you guys have any input on these ? Not a highjacking LOL!!Im trying to help guy, at the same time help me LOL
