Question about rear spring rubbers
If I pull the rear spring rubbers, will I need LCA relocation brackets to correct the suspension geometry? And will I be best off with an adjustable panhard rod? Thanks
Re: Question about rear spring rubbers
Removing the "rubbers" would be just like lowering the car the same amount with springs, so everything that would apply there would also apply to you.
I removed mine and didn't need any of those. I did wrap the top of the spring with vinyl hose though. I've heard old inner tube works too.
