Front sway bar delete?
Old Apr 8, 2008 | 05:00 PM
MeanGreenZ28's Avatar
Default Front sway bar delete?
I am trying to cut as much weight as possible because I really cant afford to build my engine right now and am still trying to improve my times. I have read alot about the front sway bar delete and was considering doing it. I was wondering if anyone on here has done it and can tell me more about it, I know its going to chew up my front tires but at what rate? Is there anything else I can do to cut weight thats not completly gutting my car?( I do still want it to be kind of a street car)
any information you can give me will be greatly appreciated, thanks
Old Apr 8, 2008 | 05:13 PM
hpjunky98's Avatar
Don't take it off If your going to run it alot on the street. This is a track only mod.
Old Apr 8, 2008 | 06:14 PM
SOMbitch's Avatar
I think I have seen quick disconnect kits somewhere but can't swear it was for an F-body.
Old Apr 8, 2008 | 08:33 PM
transam69230's Avatar
I took mine off, its a just a weekend warrior, and strip car you will be fine IMO. I drove the track that was 120 miles away and i no problems. Actually when i disconnected and left in the car i pulled the front wheels off the ground. Now i got it out of the car with UMI k-member and front lcas installed, it should really pull the wheels now.
Old Apr 8, 2008 | 10:10 PM
GregWS6&z28's Avatar
i hardly notice mine is gone on the street
Old Apr 8, 2008 | 10:14 PM
waterbug1999's Avatar
Just take it off and see how you like it.. Some dont mind and dont notice it, and some wont drive with out it.
I leave mine on on the street and take it off when going to the track.
Old Apr 8, 2008 | 10:27 PM
Shockwave179's Avatar
Johnny runs with his off. I personally think our cars would handle like **** without them but its up to you.
Old Apr 8, 2008 | 11:39 PM
studderin's Avatar
take it off and see what you think.
Im fine with it off.
btw when we gona line up?
Old Apr 8, 2008 | 11:55 PM
sixvi6-camaro's Avatar
Here we go again... the start of another Drag car guy vs corner carving guy thread..
https://ls1tech.com/forums/suspension-brakes/682351-street-driving-w-out-front-swaybar.html
Old Apr 9, 2008 | 12:02 AM
lemons12's Avatar
i got mine off.. DD my car.. didnt notice a LOT.. just dont be stupid at take corners fast w/o it on.
Old Apr 9, 2008 | 12:55 AM
caliswangin916's Avatar
had mine off for over 30k miles. no noticeable difference on tire wear after an alignment. it will let the car raise up about 1/2" or so. not to great on handling. right now i personally wouldn't take it off for weight savings. but then again i haven't gotten to wanting to reduce weight.
Old Apr 9, 2008 | 07:47 AM
95GreenZ28's Avatar
https://ls1tech.com/forums/showthread.php?t=682351
Haha thats what I was thinking I took mine off and I drive it on the weekends and at the strip every now and then. Noticed very little difference with it off. It does remove some weight for sure.
Old Apr 10, 2008 | 04:55 PM
haha i actually have to get my car on the road in a couple weeks because i dont want to finish putting my girdle on with out a lift bcuz i can't really get my torque wrench in there. when you do them do you take the panhard bar off and that other bar across the top off?(don't know the real name of it)
and i cant get to my o2 sensor bcuz my jack dosent go high enough and that has to be changed. then i just have to get my manifold on and my fuel pump in and get my car tuned again from you guys, then i'll race you.
Old Apr 10, 2008 | 05:24 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs down
Had mine off once for 2 days..waiting for new Hotchkiss brackets...will never drive it again without a front swaybar....never...handled crappy..and bouncy/unstable around turns.........
Old Apr 11, 2008 | 03:20 PM
z28bryan's Avatar
Even that thread is crappy. There was a more informative thread before that one that had explainations of what occurs/changes when you remove the front swaybar vs keeping it on.
Old Apr 11, 2008 | 03:31 PM
z28bryan's Avatar
This thread is a little better https://ls1tech.com/forums/showthrea...front+removing
That thread above is completely useless. Just a bunch of people saying do it or don't do it. Though I would recommend to noobs to look at Foxtron's or Sam's advice over all the others in there, or anyone who understands suspension over the people who say "I do it and haven't had any problems"....
