Torque arm...which body mount is the best...
I need to get the torque arm off of the tail shaft because right now the stock bracket is bent pretty bad from 1.5s 60fts....which body mount torque arm is the best for 60ft and has great clearance...also chromoly is a plus...thanks
Hello,
We offer (4) different styles of tunnel mounted torque arms (all linked below) We offer them for different exhaust systems and with or with out drive shaft loops. They are all also available in Chrome Moly. They fit the factory rear end as well as the 12-Bolt, 9" and S60. They also offer instant center adjustment in the front. The white Trans Am in the second video in this link is running one- http://www.umiperformance.com/page.php?page=videos
If you have any questions please ask and I will happy to assist you.
www.umiperformance.com/2200
www.umiperformance.com/2201
www.umiperformance.com/2202
www.umiperformance.com/2203
Thank you!
Ryan
Thank you!
Ryan
I have a UMI torque arm and its pretty sturdy but....BMR's setup is way better though. It welds into the subframe connectors (which is a must have if you are getting a bmr setup) but I assume you already have that since your pulling such low times. So for serious launching like your doing I would definitely suggest BMR
LS1Tech Premium Sponsor
We provide a crossbrace to mount the torqure arm directly to your subframes instead of the sheet metal floor where there is no structure. Kind of a no brainer huh...
However it isn't a true tunnel mounted torque arm. The tunnel mounted torque arms you see above are shorter arms that mount into the tunnel area of the vehicle. The shorter arm will transmit the weight of the car back quicker. The arm you mention above is a long stock length torque arm that bolts into a transmission cross-member.. its virtually the same as using a stock length torque arm and a relocation kit. It is about 8"s longer then our short tunnel mounted arms.
uhhhh... by the way.... i do have a true tunnel mounted torque arm assy. fits the stock type mounts. this is one of the first components i started producing for the f-body's. and guess what... i even have the same thing that works with dual exhausts...
they feature an adjustable pivot link that connects the crossmember to the arm. the arm has a teflon lined aircraft heim joint to let the suspension articulate and not bind, and the link is connected to the crossmember with a Energy Suspension poly bushing to prevent noise on street cars. a solid bushed version is also available for the track-only cars.
bolt-in design, no welding needed. torque arms are chromemoly construction and tig welded, all designs adjustable front and rear. all designs include a NHRA legal driveshaft loop at no extra charge.
www.umiperformance.com/2205
www.bmrfabrication.com
Also, keep in my mind that the fastest stock suspension F-bodies use BMR products. We are the only suspension company on this board with customer cars that run in the 7 second zone. All of our 7-second customers use off-the-shelf suspension parts.
