Aerospace Street-n-Strip front brake kit > QUESTIONS
Old 04-11-2008, 11:00 AM
JEB99TA's Avatar
Default Aerospace Street-n-Strip front brake kit > QUESTIONS
1. If you were me, would you do aftermarket (BMR, UMI, or PA) brand upper and lower control arms when I install the front brake KIT?
2. If so, ajdustable or non-adjustable?
3. Does anything have to be modified if I install both at the same time?
Old 04-11-2008, 12:24 PM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
If weight saving is of concern( I would assume it is if you are doing brakes) I would do just the non adjustable lower A-arms they will save you a couple of extra pounds and the adjustability is not needed. The upper A-arms are the same weight as stock so they offer no weight savings.
The upper A-arms are a stronger unit with poly bushings which move freely and help with weight transfer during a launch.
Our A-arms can be found here-
http://www.bmrfabrication.com/F-bodySuspension.htm
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 04-11-2008, 01:15 PM
JEB99TA's Avatar
While searching, I also saw you are, or, were a distributor of Aerospce Pro Street brakes, which I believe is what folks refer to as the street-n-strip brake kit. If you have a package of upper and lower A arms with the front brake kit in the mix, can you please P.M. me with a price. Or, if there is a sale planned or group purchase to be explored, can you please let me know the specifics?
