Which LCA do you think is better?
Old Aug 1, 2003 | 03:11 PM
FEAR THE LS1's Avatar
Default Which LCA do you think is better?
I'm still running stock LCA's I am thinking about picking up an aftermarket set.
Is there any difference between a boxed and a tubular LCA, when it comes to drag racing?
Those of you that have the adjustable, do you really get under there and make adjustments ever, is it worth it?
Thanks,
Lee
Old Aug 1, 2003 | 07:46 PM
redz_02's Avatar
Default Re: Which LCA do you think is better?
talk to some of they guys at thunder, and they run tubular lca's. PRetty good wieght difference. Anyways, i got them in the other day and they look pretty solid.
Old Aug 2, 2003 | 09:33 AM
trackbird's Avatar
There is someinformation on LCA's in the technical section of my webpage (in my sig). The info on there is from some discussions on this board at various times. It may help answer some questions for you.
Old Aug 3, 2003 | 03:47 PM
BADZ's Avatar
Moderator
There is a GP going on the that section...
Old Aug 3, 2003 | 10:39 PM
98_1LE's Avatar
The only advantage of adjustables is that an alignment shop can do a thrust angle alignment which puts the rear wheels straight with the front wheels. I prefer tubular LCA's to boxed for weight reasons. I use the LG aluminum double rod end LCA's and really like them. They are lighter and stronger than stock, and with no bushing to deflect they do an excellent job of locating the axle.
Old Aug 3, 2003 | 10:49 PM
I8AFORD's Avatar
the G2 LCAs are nice...
I noticed a big difference
Old Aug 3, 2003 | 11:20 PM
highgear's Avatar
Lakewood LCA's for about $90.
Old Aug 4, 2003 | 10:22 PM
BADZ's Avatar
Moderator
There is a MADMAN GP in the sponsors section...Same lightweight lca's and lca's...but for a steal of a price and free shipping...
Old Aug 6, 2003 | 05:49 PM
mighty mex's Avatar
i think you guys better listen to BADZ. those LCA's are BAD AZZ. he also has a PHR to match.
Old Aug 7, 2003 | 12:17 PM
30thWS6's Avatar
I was to adjust my thrust angle with my adjustable panhard rod. I thought the adjustable LCA's were for pinion angle adjustment?
Old Aug 7, 2003 | 02:27 PM
trackbird's Avatar
Pinion angle is set with the torque arm....
LCA's simply move the wheels....set them at stock length and forget them....
