sumthing knocking underneath
Old Apr 21, 2008 | 04:12 PM
matt01ws6's Avatar
Default sumthing knocking underneath
theres sumthing knocking really bad when i hit bumps in my car. i looked underneath and nothing is hitting. im thinking it may be a bushing but i gotta pull the wheel off to be sure. just wondering if anyone else has had this same problem
Old Apr 21, 2008 | 04:38 PM
Bow94z's Avatar
A Knock could be anything, Thats like saying "im sick" it could be anything
Old Apr 21, 2008 | 07:11 PM
00CaliforniaZ28's Avatar
Maybe hes "sick" of the "knocking"? [/end corny]
It would be helpful if you posted a mods list. Is your suspension stock? Any idea where the knock is coming from? Front or rear? Stock exhaust and Y-pipe?
That'll help us narrow it down a bit at least. Most common things are probably y-pipe hitting, or loose LCA bolts. But it really could be a 100 different things causing it.
Old Apr 22, 2008 | 08:43 AM
95GreenZ28's Avatar
X2 sounds like possibly the y pipe if you have upgraded exhaust. List your mods for us
Old Sep 15, 2008 | 05:50 PM
BlackWS.6's Avatar
I am having a knock from something underneath my shifter around the tranny..i just had a 3" y pipe and slp exhaust put in..there seems to be enough clearance and i took that bracket off that bolts underneath where the y is and bent it more for clearance. but there is still something knocking around the 3-4k rpms.
Old Sep 15, 2008 | 11:04 PM
slowsti05's Avatar
could be worn bushings or possibley bad struts. any specific place the noise is comming from?
Old Sep 16, 2008 | 09:23 AM
knappbunch's Avatar
Check Tranny Mount
