Best control arms to get??
I'm not sure why or HOW a control arm goes bad…besides being bent in an accident.
Is it that the bushings are bad? Cause you can get replacement poly bushings for it.
Is it that the ball joints are bad? Cause those can obviously be replaced.
As far as who's is the best…most are the same. I'm a fan of BMR stuff…never let me down.
IMHO, unless you are building a full out race car, there is very little need to implement aftermarket control arms, and then you want to make sure you check the rules before you do. My Camaro is a dedicated ESP autocross car and I run poly bushings in all locations except for the lower control arm rear bushing (aka the caster bushing) because the Poly bushings for that location only last about 1 to 2 events.
The shop may be telling you that you need new control arms because they are too lazy to replace the bushings, vs, just installing new arms. Do yourself a favor and shop around for poly bushing, there are alot of big box hot rod stores as well as some smaller ma and pop venders who can help you out.
How many miles on your car?
True, but there have been some recent posts about the aftermarket pieces not being "stout enough" for everyday driving.....
If you're having alignment issues, hog out the holes in the K-member a little more, if required, to get the alignment you're looking for. Upgrade the bushings in the A-arms, and call it a day.
