Installed control arm relocation brackets and now wheel hop
I didn't have any hop before. I put these on in hoping to get some more traction and it did help. Now right before it starts to hook in 2nd it will get a little hop, none in 1st gear. The car is not lowered and the only thing I have done under the car is subframe connectors and now the relocation brackets. I started with them set in the lower hole but now moved them up one and the hop seems to be gone or most of it anyway. Is this a normal thing to happen with the relocation brackets?
LS1Tech Premium Sponsor
You did what I would recommend by moving the control arms up one hole. Sometimes the bottom hole puts too much anti squat in the car (especially if it has questionable tires or poor road surface) and will make the car skip....
