what size rear sway bar can i run 25mm or 22mm
im looking at some rear sway bars and i dont no which one will fit. id like to go with the 25mm since there the same price....
thanks
thanks
If hardcore drag racing and your rear end doesn't like to stay straight on launches, then a bigger rear bar can help fix the problem. Might only need a 21 or 22. If its bad you might want a 25mm. A 25mm will make the car oversteer a lot quicker than with a smaller bar though if you daily drive the car. 25mm would be way too much for autox or road racing.
If you aren't doing the above (hardcore drag racing), get a 22 hollow or 21 solid rear bar if you have a 35mm front bar. Keep the 19 stock bar if you have a 32mm front bar.
