Solid vs Hollow sway bar
Old May 8, 2008 | 09:52 AM
Hatchetman337's Avatar
Default Solid vs Hollow sway bar
I'm going to be getting a new sway bar sometime soon. I have a WS6, so the rear is already the larger size. The front is what I'm looking at. I was wondering if there is a difference between the Strano hollow front sway bar and, say, a BMR or Suspension Techniques or something that is solid. I realize that the hollow bar will be lighter, but that's not really my concern. I was just curious about what will perform better. Is the hollow bar worth the extra money? It seems to be about 50 dollars more than some of the others.
Sam, I know you are busy taking care of personal things right now, but if you happen to drop in, your input is greatly appreciated. Sorry for your loss. Thanks.
Old May 8, 2008 | 03:46 PM
GuitsBoy's Avatar
I cant even begin to tell you how much heavier that suspension techniques sway bar is over the stocker. Must be close to 30 Lbs difference. I almost cried when I found out how much weight I was putting back into my mildly gutted car. I stopped crying after the first test drive though.
Old May 8, 2008 | 03:50 PM
vjo90rs8's Avatar
I love my ST sway bar.
-Heavy is good.
-Heavy is reliable.
Old May 8, 2008 | 05:54 PM
LS1W66's Avatar
Originally Posted by Hatchetman337
I'm going to be getting a new sway bar sometime soon. I have a WS6, so the rear is already the larger size. The front is what I'm looking at. .
The rear bars on a WS6 are the same as the regular Formula/Trans Am
Standard cars have a 30/19 set WS6 and SS's have a 32/19 set.
Old May 8, 2008 | 06:52 PM
coolformula's Avatar
I have had them both. The ST is GREAT, but thats a lot of weight. And not exactly where you want it.
Now if Sam thought the ST was good for most things why would have he developed his own hollow one? So that should tel you for most applications which one sam will tell you to go with. The hollow is close in the same strenght, and tons of lighter(can search to find the exact weight think it is around 30 pounds)
I like both, but I think I like the hollow one better
Old May 8, 2008 | 07:39 PM
99Bluz28's Avatar
Have you tried changing out the stock swaybar bushings and end links for polyurethane ones yet? That will help the tighten-up the handling for alot less.
Old May 8, 2008 | 07:43 PM
t-rey's Avatar
-Heavy is good.
-Heavy is reliable.
if you run out of bullets you can always hit him with it
hahaha...****** is a great movie
Old May 8, 2008 | 09:33 PM
My mistake! For some reason I thought the rear was the larger one on the WS6. In that case, how advantageous will it be for me to also upgrade the rear bar?
Old May 8, 2008 | 09:54 PM
JD_AMG's Avatar
Very.
I had just the 35mm front bar on and stock rear bar, the car felt unbalanced, like the rear was just on its own back there. Rear bar made everything balanced again (if you match them i.e. 25mm rear bar is for drag racing and will only cause oversteer).
Old May 8, 2008 | 10:06 PM
That's good to know. Unfortunately the Suspension Techniques rear bar is 25mm, so it looks like the Strano might be the way to go.
Old May 9, 2008 | 07:40 AM
So would the BMR front sway bar be an upgrade at all for me? They advertise that their bar is 40% stiffer than the 1LE bar, but aren't they both 32mm? I'm just trying to figure what's going to be more cost effective, ya know?
Old May 9, 2008 | 08:56 AM
SOMbitch's Avatar
I went Strano set cause they are matched and lighter. About the same weight as stock but much stiffer. Best of both worlds.
Old May 9, 2008 | 08:58 AM
GuitsBoy's Avatar
But heavier on the wallet. Thats the only drawback, otherwise hollow bars would be the obvious choice each and every time.
Old May 9, 2008 | 09:03 AM
brapril714's Avatar
I have the ST set and love them. Yes, the front bar is heavy. I've heard the 25mm rear bar will cause oversteer, but haven't experienced it yet. I don't autocross, just a play car. I've notice I hook alot better with the 25mm bar vs the factory and the cornering is night and day with the whole setup.
Old May 9, 2008 | 09:13 AM
I don't autocross either. This is just my summer toy. I drag raced it a lot last year but this year it's not going to see the track more than 2 or 3 times, likely. Maybe that oversteer is only really noticeable when you're racing. I'm only thinking about this so much because that ST set is like 280 dollars and the Strano set is 430! That's a big difference!
Old May 9, 2008 | 09:42 AM
z28bryan's Avatar
I measured the difference between my ST bar and my Strano bar (fronts) on my crappy bathroom scale.
The Strano bar was ~11 lbs lighter than the ST bar. Seems like hollow bars are the way to go. I don't know the equation, but a solid 34mm bar would probably be pretty damn close to the same stiffness as the 35mm hollow only with a lot less weight
Old May 9, 2008 | 10:32 AM
vjo90rs8's Avatar
You can look for a 21mm rear bar from a thirdgen camaro/firebird. Do some research on thirdgen.org. I used to research the hell out of thirdgens since my first car was a 1990 Camaro RS 305TBI, so I knew they were out there. Found a guy parting out a 83 WS6 and got his rear bar for next to nothing. Junk yard are also a good choice if you don't mind crawling around on the dirt.
Old May 9, 2008 | 10:39 AM
CranMaro99's Avatar
True, but you get what you pay for.
Old May 9, 2008 | 10:54 AM
GuitsBoy's Avatar
My eyes bleed a little every time I read that statement. Nothing personal, man.
Old May 9, 2008 | 11:06 AM
Have you ever noticed oversteer with the ST 25mm rear? Huge improvement over the stockers?
