torque arm mount is busted
Old May 12, 2008 | 10:47 PM
droptopT/A's Avatar
Default torque arm mount is busted
which one do i get poly or stock
Old May 12, 2008 | 10:55 PM
99Bluz28's Avatar
If you don't mind a little more noticeable vibration, and want a better launch, go for the poly!
Old May 13, 2008 | 05:47 PM
leadfoot4's Avatar
Is the MOUNT broken, or the RUBBER CUSHION broken. If the entire mount is busted, you'll have to get a new GM torque arm mount first, then decide whether you want to go with the poly cushion.
Old May 14, 2008 | 11:20 AM
djjab57's Avatar
If you deside you want a poly check out the one i have on ebay here is the #290199411098 or i have one that is the same but is red and out of the package but everything is there will let it go cheaper pm me if intrested
