question on adj PHB....
I just installed an adjustible pan hard bar. It had no instructions on how to adjust. How close is close enough? Is 1/32-1/16" close enough? That's where mine is sitting right now. I adjusted mine to factory length and this is what it reads.
If this is close enough I don't even need an adjustible bar. Might as well reinstall my factory. I thought an alignment shop would have to set it. Too bad I didn't have this info before purchasing the bar.
First a BMR Chromemoly adjustable with the center adjustment bolt, and MADMAN's billet aluminum with the jam-nuts on either end.
I found the style with jam nuts on either end to be MUCH easier to adjust than the center adjustment bolt. Loosen up the jam nuts and then just grab the bar and twist.
