Brake ?'s
Old May 26, 2008 | 10:07 AM
Firehawk#286's Avatar
Default Brake ?'s
'99 Formula:
1) Removing the front calipers, I noticed the top caliper sliding pins on each of the calipers would not come out of the caliper bracket. Are they ceased in the brackets, or are they suppose to be that way? I can't see how they should be that way, as it won't allow the caliper and bracket to slide in and out on each other, using the pins.
2) I need to bleed my brakes. Haynes suggests bleeding the ABS modulator. WHere is it, and what does it look like?
Thx,
Old May 26, 2008 | 03:43 PM
No one?
Old May 26, 2008 | 10:02 PM
BigE's Avatar
Yes, they are seized. I've had this happen on both of my Formulas. My 98 came from St. Louis, my 02 from Frederick, Maryland. If the slide pins are not kept greased, rust can form and lock the pin in. Both times, I used a large screwdriver on the head of the pin to drive it out with a hammer. I then cleaned out the bore and replaced the pin with a new GM part using synthetic caliper grease. Caliper slides like a dream.
As for the modulator, it's the aluminum block between the power steering pump and the driver's side shock tower with 4 brake lines coming out of the top. However, I've read that it's not necessary to bleed it unless you've opened the system up stream of it (ie. replacing the master cylinder. I have bled brakes after installing a line lock before without bleeding the modulator, though. And for what it's worth, I don't believe there are any ports on the modulator to bleed. You have to actuate the internal solenoids and bleed at the calipers. Again, I have never done this, it's just info I've gained through research so take it with a grain of salt.
Hope that helps.
Old May 27, 2008 | 08:14 AM
Hope that helps.
Thx E. I consulted a mechanic friend of my son's, and he confirmed what you said, regarding not having to bleed the modulator. It was referenced in my Hayne's manual, but probably for their own protection...and overkill. If the brakes are bled properly at the calipers, the air will pass through the modulator and out the bleed valves at the calipers anyway.
The pins will NOT come out of our brackets, so we were trying to source some used caliper brackets (such as reman'd. ones, or ones from guys parting out their F-bodies). Time has run out though (need to get the car on the road...it's my son's DD'er), and we're purchasing reman'd calipers (w/brackets) from Advance Auto, just so we can use the brackets from them. We'll then return the reman'd. calipers we just bought (plus our old brackets) as cores, so we won't have to pay the exorbitant core charges.
It boils down to a very poorly designed caliper, with a small and flimsy dust boot that keeps very little or nothing out of the pin "hole" in the bracket. Oddly enough, Dorman offers aftermarket brackets (without having to buy a complete caliper to get it), but only for the rear brakes, not the front !? No one else seems to offer just the brackets for the front.
Old May 27, 2008 | 08:25 AM
BigE's Avatar
I hate to see you spend all that money just for brackets and pins. Have you tried heat? Also, the pins are completely round. You should be able to get a pair of vice grips on them and twist to break them free, then pull them out. You'd still need to replace the pins but it wouldn't be near as expensive as buying the whole assembly. Also, there's an F-body salvage yard here in Alabama called Billy Graham's Camaro and Firebird Salvage if you're looking for used parts. Some parts are outrageously expensive, some are reasonable. Just gotta call and ask. Good luck.
Old May 27, 2008 | 09:15 PM
Tried PB Blaster, vice grips, hammer and vise, heat, even drilling one out. Nothing worked. If I didn't know better, I would swear the pins and brackets were all one piece! Found two front brackets at a local salvage yard here, but they wanted $45 ea. Shoot, for $63 ea. at Advance Auto I can get complete reman'd. GM calipers, brackets, pins, and all hardware...everything but pads! Picking them up tomorrow, along with some new front rotors. Should be good to go. Thx for the advice, though.
Old May 29, 2008 | 08:28 PM
caddobass's Avatar
A 5/8 will fix the pins, I've had to do alot of turning on them but they will free up and come out. There are two flat sides at the end where the boot is.
