Isolator and Heater Hose Trick on Lowering Springs to fit 315's?
Hey I'm just wondering if you can use the spring isolator and the heater hose trick on lowering springs to raise my rearend up a tad bit to fit my 315/30/18's?
that probably isn't the safest thing to do, but i've heard of worse. if you already have the isolator in then i'd look into getting a spring that makes the car sit higher. if you have the heater hose mod done, yank the hose and put in the isolator. i probably wouldn't run both though...
