what springs work well with bilstein hd's?
i had bilstein hd's (not revalved) and stock springs right now.... is there any spring i can use with these shocks without a problem? eibach pro kit maybe?!
The HD's were not meant to handle anything but stock springs, so they are not going to be ideal for less travel, or higher spring rates. You may get a floaty, bouncy ride, if not at first then later when they get worn down.
well i definately like the HD's better than the crappy stock shocks... but even with the HD's the ride still seems really floaty/bouncy and not stuck to the road.... what could be the cause of this?
