Gonna ditch the prokit...
Old Jun 3, 2008 | 01:07 AM
DarkhorSe_SS's Avatar
Default Gonna ditch the prokit...
like it states, I'm going to be going a different route and will be selling the prokit. I have them currently on the car for about 4 months I believe and less than 4k miles on them. Bought em brand new but I need a stiffer spring due to my Td's already being low. Not sure what springs I'm leaning toward but my first option is going to give strano a buzz in the morning. I'll let em go for $150+ shippin
Don't have pics since their on car and like I said they are 4 months old the most... lmk if interested
Old Jun 3, 2008 | 09:30 AM
z28bryan's Avatar
Did you run into any problems? Why do you want to get rid of them so quickly?
Old Jun 3, 2008 | 09:46 AM
lt1noob's Avatar
the problem is his true duals from what it sounds, i just got mine on and theyre great springs but yes, if i did do true duals i would definately have a problem.
Old Jun 3, 2008 | 10:35 AM
clearance for 1 but I definitely need a stiffer spring
Old Jun 3, 2008 | 10:52 AM
Alex L.'s Avatar
Are your shocks adjustable? If they are just stiffen them up a bit and that will be like having a stiffer spring.
Old Jun 3, 2008 | 11:45 AM
Sam Strano's Avatar
LS1TECH Sponsor
That's not how it works. Shocks are dampers, they slow motion... they do not add wheel rate like higher rate springs do.
__________________
Old Jun 3, 2008 | 02:46 PM
Alex L.'s Avatar
Damn just when you think you know something! Thanks for correcting me Sam.
Old Jun 3, 2008 | 02:57 PM
z28bryan's Avatar
Correct. It definitely isn't anything like having a stiffer spring. Especially for the Konis that he has. Compression stays the same. You only adjust rebound. So his car's suspension will compress the same. It won't return that fast though and keep the car low for a longer period of time. The next bump you hit will have less suspension travel, especially if the bump is sooner than later.
