Coilover question
Old Aug 15, 2003 | 12:33 PM
Sniper33's Avatar
Default Coilover question
If I run a set of coilovers (poss Ground Controls) with Bilstein shocks, do I need an adj. panhard and relocation brackets?? Also, everytime I change the ride height, will I have to adjust the panhard??
Old Aug 15, 2003 | 04:47 PM
trackbird's Avatar
Default Re: Coilover question
When you change ride height, you may need an alignment.
I've never had to adjust a PHB on either of my cars, stock length has worked just fine for me, so if you are moving the height 1/4 inch or so, you'll probably never see it (as far as adjusting the PHB).
Just my thoughts...
