SLP Driveshaft Loop
Old Aug 16, 2003 | 09:21 AM
MJMZ28Cvt's Avatar
Default SLP Driveshaft Loop
I have an 02 Z28 Convertible and I am looking to make the body as rigid as possible. I have double diamond SFCs and a STB. Would adding the SLP Installation Kit/Crossbrace (p/n 30055) along with the driveshaft loop (p/n 65050) make any difference? Any convertible people here have these mods? Thanks!
Old Aug 16, 2003 | 10:21 AM
DGOETZ's Avatar
Default Re: SLP Driveshaft Loop
I like the factory unit better than the SLP.
I thought the SLP unit was for header installation.
Old Aug 16, 2003 | 10:54 AM
MJMZ28Cvt's Avatar
Yes the installation kit is for header/y-pipe installation but it also allows you to put on the driveshaft loop. I thought I head that people who installed a driveshaft loop felt their car was tied together a lot better and worked well with the SFCs. I'm not sure though.
Old Aug 16, 2003 | 12:14 PM
DARK AGE 53's Avatar
If you have the stock y-pipe there's a good chance the SLP drive shaft loop will hit the y-pipe under hard acceleration.
Al
Old Aug 16, 2003 | 02:51 PM
MJMZ28Cvt's Avatar
Al
Ok then, forget that. Thanks for the info.
Old Aug 17, 2003 | 12:12 AM
jimmyblue's Avatar
Moderator
If you're talking about the "convertible brace",
don't waste your money or effort. I bought one,
it's a spindly POS that doesn't fit the existing
bolt holes and binds my SLP Y-pipe with no fix
that I can see, other than leaving it in the
closet and off the car. Junk. Junk. Junk.
I'm only calling it "junk" because if I said
what it really is, I'd be censored.
Beside which, the rear piece is only the same
kind of stamping as the M6s get from the factory.
