G2 Torque arm install?
Old Aug 20, 2003 | 08:35 PM
skippytheloon's Avatar
Default G2 Torque arm install?
I know to jack the car level with weight on axle and keep transmission up there. anything else I might skrew up?
Anything would help: torque specs, tips? Doesn't look very hard, just wanna be careful in this area
Old Aug 20, 2003 | 09:25 PM
Fulton 1's Avatar
Default Re: torque specs for Torque Arm
The two big bolts to the rearend housing are 97ft-lbs.
The attach bracket to transmission tail shaft is as follows (note that this assumes M6):
Upper bolt - 20ft-lbs
Forward bolt - 37ft-lbs
Both Nuts - 33ft-lbs
Old Aug 21, 2003 | 07:08 AM
mitchntx's Avatar
I know that is what the book says for a stock TA ...
I suggest you bust the inner lining of your abdomen wall tightening those two rear bolts. And after a day or so of driving, check again.
To get the bolts out, you'll have to let the rear droop. Level is not an issue. The only pivot point is on the trans and it's spherical bearing. So it won't pre-load or bind.
Old Aug 25, 2003 | 03:40 PM
Craig98Z28's Avatar
Speaking of those rear torque arm bolts... Anyone know which way they're supposed to go? Bolt head on top, or bottom? I took mine off and can't remember which way the bolts are supposed to go
Old Aug 25, 2003 | 04:10 PM
Fulton 1's Avatar
Bolt head on top, nut on bottom.
