Adjusting Koni Rebound - Pics Inside
The factory shock has a nylon insert to keep it from loosening but they are a pain to thread on the shaft, plus the added resistance can sometimes cause the shaft to turn with it.
The jamnut method is easier and better in my opinion. I'm also pretty sure the nuts are the same size.
Wow, you really tighten them all the way down until that rubber bushing is the same width as the washer? Haha, This would explain why I'm having such a B**CH of a time on bump when I hear BAM in the rear end like it's loose as crap. Seems to be much worse when extra people are in the car. I'll check on that and get back to you.
I also have the top part (the adjuster) all the way tight. I might be able to back that off a little bit now if I can get it to stop sounding so loose when I hit bumps. What exactly does the adjuster, adjust? What type of things am I looking for when I drive to know if I should tighten or loosen? Thanks guys.
Try turning both rear shocks to full soft. You will notice the back end of the car leans a little more when you turn the front wheels quickly, but it will ride much smoother. If you want to slow down the rear lean, such as in a slolom or to slide the back end out, then adjust it a bit firmer.
Most folks run the rears full soft or almost full soft.
Ok, they are all the way left (soft/loose). Still making the noise. My next guess is that there are spacers under the bump stops, Why? I dunno, is there any reason for those to be there? Or should I just remove the spacer part?
Yes, problem only seems to happen when I hit a bump. I have subframe connectors and aftermarket LCA's. It never made this noise before and I haven't changed anything so I don't quite know what it could be. I'll try taking off those spacers and see if it gives it enough room.
What's probably happening is that the lca bolt is not tight enough. On the sfc's that add tabs to that front mount, it makes that bolt hard to tighten enough to hold the inner steel arm bushing. Under acceleration it pushes the bolt forward and when you hit a bump it pushes that bolt backward. Over time it will elongate the hole. Plus it makes that popping sound.
Try loosening that front bolt and see if the arm is a snug fit. If not, you can push the tabs closer with a hammer blow. Another way would be to add a thin washer in there to make the fit tight. Then really crank the bolt tight. That will usually fix it.
#34
I'm confused... I started adjusting my front shock firmness - and I kept rotating the adjuster with the allen wrench hoping I would eventually hit a "stop" point - but it seemed to continue rotating forever. It just kept going and going and going... Is it supposed to eventually hit one or the other end and stop? Or what am I doing wrong??
#36
#37
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#38
Sorry for the thread bump, but this seems like the best place to ask this.
I bought my Koni SAs used, and they did not include an adjuster **** for the rears. I've done a bit of research and discovered that Koni made two different kinds of ***** -- one with a "neck" that sticks out from the bottom, and one with a flat bottom. I've not been successful in finding a single photo of a Koni **** that shows the bottom, so I'm only going by descriptions I've found. It's unclear to me why there are two designs, or whether it matters which I use -- but I was hoping someone who has the original **** that came with the Koni set could look at theirs and tell me whether there's anything protruding from the bottom of the ****? Once I have that information, I'll order one from eBay.
The diagram in post #10 makes me think I want the one with the neck, but I don't know if that's a generic diagram from Koni or an accurate depiction of the specific setup for ours cars.
Thanks!
EDIT: I also reached out to Koni via their website. Got a response after just a few minutes! They said I want the flat-bottom *****.
Thanks!
