Cross drilled and slotted rotors!!!
9 Second Club NA
So if pads these days dont experience that problem anymore and the slottled and drilled rotors are just for looks, then do performance rotors exist? If so, what makes them performance? I too need a set of new rotors because Im tired of them warping. I too thought that the slots and holes were for heating purposes, but I now know they are only for looks. So I dont necessarily need slots or holes to improve my braking? How does holes and slots shorten the length of the life of the rotors? Even if pads dont experience that problem anymore, wouldnt slots and holes still cool or keep the rotor cooler than ones without? Thanks
Just my thoughts.
Just my two cents but two of my friends swapped stock rotors to the Baer Eradiaspeeds upgrades and both said there was a noticeble difference in braking performance. Both of them are still running the stock pads. One runs a Supercharged Z06 the other a H/C SS both people are well versed enough with aftermarket parts to be able to "feel" a difference as opposed to being "tricked" into a difference.
maddboost, SOTP feel is subjective, at best.
Not trying to discount the expertise of your friends, but it wouldn't be the first time that someone's SOTP feel was driven by the weight reduction in the owner's wallet.
I've run blanks, slots, holes, veined, directionally veined and most combinations ... but never a 2 piece.
Maybe that's the difference ...
9 Second Club NA
I like the slotted and drilled rotors for look purposes, but theres no gain with them. However, they do affect the life of the rotor in a negative way.
1. Can slotted/drilled rotors be turned? About whats the life expectancy for a slotted/drilled rotor?
2. Will even a decent set of drilled/slotted rotors be an upgrade from the factory ones?
3. Would I be better off using a solid rotor?
4. What are viens and does anyone have any pics?
I know that the braking is terrible and theyre "out-of-whack", so I'd like to put on a decent set. In most cases, the better something performs, the more it wears.
5. Does this apply to rotors?
6. Will you really be able to notice the wear on the rotors? I mean...theyre not going to wear out in 6 months are they?
Well, dont want pile all the questions in one reply so...Ill stop here...for now!
Thanks
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
My thoughts....
9 Second Club NA
If slotted/drilled rotors cant be turned...then when they warp, what do you do to fix it? Or once theyre bad, theyre bad?
What are some/all the brands that people are having trouble with warpage and other related problems?
All rotors have veins, but do all of them have directional or curved viens?
Do you consider ceramic pads race pads? I wanted to try out a set because Ive got a set of performance frictions from Autozone and they suck! They put out so much damn dust its crazy. Do you have a particular brand that you prefer on pads? Oh...is ceramic the way to go? I hear that they put out little dust and stop noticeably better than factory pads. What kind of life for the rotors can you see with ceramic?
So...if thats true, what makes a set of aftermarket solid rotors or even ones with slots/holes an upgrade from stock ones and how does it decrease the chances of warping?
What makes Brembo and Eradispeeds different from all others? Thanks
Most rotors are made of the same material (or materials that are similar enough to have the same characteristics for hardness)
My thoughts....
