Rear Sway bar size??
The 1LE optioned cars came with the larger 21mm rear bar. The SS did come with the larger 32mm 1LE front bar instead of the standard 30mm. Maybe that's what you were remembering. You can pick up the 1LE rear bar from SLP I believe for pretty cheap.
