What pinion angle for UMI torque arm on Strano-lowered Z28?
well Im in the same situation as the OP, I had my koni 4/4's and strano springs installed a few weeks ago and am now waiting in the TA to arrive. I was told, by Mr Strano, that if Im having no binding issues that the easiest thing to do would be measure the current pinion angle and duplicate that when I install my TA, either that or just go with Zero.
In theory, If your car is as the OP said lowered on strano springs, but you dont have any binding couldnt you just measure the pinion angle with the stock piece and then tune the adjustable TA to mimic that?
Not my idea so I cant really take credit for it, but that should work fine.
Something to add about the BMR video. The video says "rear end minus driveshaft angle", which is wrong. It should says rear end plus driveshaft angle.
Example: the video has +2 driveshaft and -5 rearend. So by their method it would be -5-2=-7. You don't want go off of that number. The correct math would be -5+2=-3.
Jon
Edit: to any one reading this, the BMR video math is wrong. It actually would be -7. This threads explains the correct way to set pinion angle:https://ls1tech.com/forums/suspension-brakes/974198-measuring-pinion-angle.html
No. Set it 1-2 degrees negative. It doesn't matter what the stock one is, unless you are using the stock one.
Example: the video has +2 driveshaft and -5 rearend. So by their method it would be -5-2=-7. You don't want go off of that numbers. The correct math would be -5+2=-3.
Jon
Jon
