Sloppy steering
I know that's a lot of questions at once, but thanks for any input you all may be able to provide!
If all of those are ok, I'd try to detirmine how much slop there is in the steering rack. See how far the wheel can be turned before the rack starts to move (there will be some slack, but I'm not sure of the "acceptable limit"). If the rack looks reasonably tight, I'd start looking at alignment specs, maybe the alignment is out and that is causing the problems.
There is no "set answer", but those are good places to start.
Good luck.
Kevin
Pretty much all the easy suspension has been redone or replaced. Shocks, springs, swaybars, LCAs, panhard rod. I haven't done the Torque arm yet.
Thanks for the info!
Kevin
