installing springs, LCA's,and panhard rod tomorrow any tips
This is the first time I have tried to install any suspension parts and was just wondering if you guys had any tips that might make things go a little smother.( or keep me from screwing anything up
Thanks , justin
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Thanks , justin
Get spring compressors, and a torx 40. use the spring compressors for the front to not mess up the not on the shock. And to get the rear springs out, lay on your back and the car rigt above you. and press the springs out from the bottom. It took me 5 mins to do the rear. If your not the strongest of people, get a pry-bar. oh and check this out too jmXs web page
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
