My new stance!! Slam!!!!!
If you have the saggy rear problem with the pro kit likw they all do add a rubber hose around the top coil of your rear spring and keep your rear isolators in and it will level it off. See the DMS springs sit high in the rear so i have the hose around my top coil with no rubber isolators to lower my rear
its came with the deal with wheels and tires! They only had 300-500 miles on then and the front had some sportsman 4plys on the front but i took them off. The setup i got new would cost $1,500 i got the set for $800 that were basically new. The next set of rear tires will be 1.6" wider
Centerline convo pro's
-15x4 with 165/80r15 kumo's loving the new tires it did have 26x7 sportsmans 4plys
-15x9 6.5 back spacing with 26x10 M/T sportsman S/R's
-No spacers
-Works on stock wheels studs
-1/4 the grinding you would do on weld wheels
-No spacers
