IRS for 2000 LS1 camaro? is there such a kit?
is there a bolt in Independent Rear Suspension (IRS) kit for 2000 LS1 camaro?
the kit must not have the leaf spring so that it does not resemble the solid rear axle (i mean to be completly independent rear suspension).
the reason i want the IRS kit is that the car will be more glued to the ground much more with the IRS than with the solid rear axle specialy during a street race.
thanks for the replies.
NO. There is no kit. It has been done before, but it used the C4 rear suspension (there is actually a huge thread about it if you search irs). I would love to see someone do it using the C5 (or similar) setup.
I've thought long and hard about doing it (on my third gen especially), but unless someone "donates" all the parts, I seriously doubt I'll do it.
