How do you adjust Koni rears
Old 08-23-2008, 01:12 AM
98 4mula's Avatar
Default How do you adjust Koni rears
i've read the other posts and know that they adjust from the top but when i go to adjust with some pliers it keeps spinning both ways. Am i supposed to hold the nut below it while i adjust?
Old 08-23-2008, 07:09 AM
LS1W66's Avatar
Are you referring to the 4th Gen rears or the 3rd Gen ones ?
Cause the 3rd gen ones can only be adjusted off the car.
The 4th gens come with an adjustment ****.
Old 08-23-2008, 02:45 PM
98 4mula's Avatar
4th gen, i don't have the adjusting ****
Old 08-23-2008, 04:01 PM
sixvi6-camaro's Avatar
If the shock shaft is turning when you are adjusting the shocks I'm thinking you should tighten up the nut holding the shock on more. All you should need to do is use some pliers and turn the small flat piece that sticks out from the shock shaft. That is all the **** does that koni supplies
Old 08-24-2008, 10:50 AM
EvilBLK02TA's Avatar
whatever he said
Old 08-24-2008, 05:52 PM
98 4mula's Avatar
it seems like the little shaft is stuck, i cant move them in either direction. thanks for the replies. that picture helped alot
Quick Reply: How do you adjust Koni rears
