DS Loop / DS clearance issue (pics)
Old Sep 18, 2008 | 08:05 PM
2000_SS's Avatar
Originally Posted by JonCR96Z
I was looking at the first picture and think it was on the top and bottom. If it's just the top the bend the loop up or shim the tranny down (remember to check you driveshaft and pinion angles if you shim the tranny).
that's a good thought....i didn't actually think about shimming the tranny down, i was concerned with the DS loop itself...
can anybody think of any reason i couldn't do that?
Old Sep 18, 2008 | 09:16 PM
JonCR96Z's Avatar
I would try bending it up first. Put a jack under there and a 2x4 or something to reach the loop
Old Sep 18, 2008 | 09:18 PM
2000_SS's Avatar
well the car is 100% disassembled, i can pull it off and work on it on a workbench...
...but i don't think i wanna do that so much. i know it would crack the powdercoat, which in itself isn't too bad, but it would allow rust to have its way with the bar...plus i don't know if it's a bar, or a tube. if it's bar stock, i'm not going to be bending on it
Old Sep 18, 2008 | 09:25 PM
JonCR96Z's Avatar
As nasty as is looks in the pics you'd never know. Just paint it. With that said how about grinding or cutting part of the loop off where it is rubbing.
