Torque arm install doc?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Just ordered an adjustable torque arm. Has anyone made an install document for this? I've got a Haynes manual, but it's nicer to not go in totally "blind".
Yes as Leadfoot stated above check the video out. Very easy install though. Make sure you have the suspension unloaded when you do it.
just take out the 2 rear bolts on the diff. and then the 3 on the back side of the tranny, then pry open then old mount and peel out the old bushing and put the new one back in, then install all your bolts. once in make your measurements for your pinion angle using the angle finder, and viola, all done!
LS1Tech Premium Sponsor
As the others have mentioned the video on our web site is very informative. You can also access our instruction sheets for our torque arm install off of our main page.
http://www.bmrfabrication.com/index.htm
http://www.bmrtvonline.com/video_detail.php?mId=3788
