4th Gen Bump Stop Dimensions?
I had to trim about 3/16" off the bump stop, where it would hit the part of the inner fender that is "folded over".
I don't have a digital camera, so it isn't easy to take/post pics. I just put a fresh roll of film in the 35MM, and I'd rather not take and process/print 24 pictures of the bumpstop.
I was going to avoid cutting off the bump stop mount lip, but the lip doesn't do any good with the ES bump stops. What I did is cut the lip off, then I cut and trimed a 3/16" thick 5" x 1.5" piece of metal to mount between the bump stop and mount since the mount doesn't offer enough structual support IMO, for the ES bump stops. They would probably be fine without the metal support plate I installed, I just felt better with them in there.
I also cut 1/2" off the bump stop height to give me more drop with my air bags. And yeah, with the mount lips cut off they bolt right up !
Previous bump stops. http://i523.photobucket.com/albums/w...ication002.jpg
Mount lip cut off. http://i523.photobucket.com/albums/w...ication005.jpg
painted bare metal. http://i523.photobucket.com/albums/w...ication008.jpg
ES. BS. top view mounted NO support spacer.
http://i523.photobucket.com/albums/w...ication014.jpg
ES.BS. side view NO spacer http://i523.photobucket.com/albums/w...ication013.jpg
ES.BS. angle view, NO spacer. http://i523.photobucket.com/albums/w...ication011.jpg
ES.BS. far side view NO spacer.
http://i523.photobucket.com/albums/w...ication009.jpg
3/16" support spacers I cut ,drilled , and painted.
http://i523.photobucket.com/albums/w...topmod2008.jpg
ES.BS. side view mounted w/spacers. http://i523.photobucket.com/albums/w...topmod2011.jpg
ES.BS. far side view, mounted w/spacer.
http://i523.photobucket.com/albums/w...topmod2012.jpg
3/16" thick support spacers, side view.
http://i523.photobucket.com/albums/w...topmod2009.jpg
Im really glad I saved this page in my favorites knowing that this would happen one day...i changed out my LCAs tonight...
Both of these are frikin annoying.
http://s249.photobucket.com/albums/g...23-08_2133.flv
