clicking in front end
Old Sep 19, 2008 | 07:19 PM
camaro468's Avatar
Default clicking in front end
got a clicking in the front end only win truning right or left every thing sems tight cant figure it out trying to pin point it not wanting to just start replaceing parts any ideas ?
Old Sep 19, 2008 | 08:59 PM
Major_Lee_Slow's Avatar
I had the same issue, but only when backing up and turning left. Turns out my 17x11's with 315's on the front would catch the inside of the fender lip on the front edge
I don't suppose you are running 315's up front are you? You may want to jack the car up take the tire off and look for rub marks. What have you done so far to trouble shoot the issue?
Old Sep 20, 2008 | 07:50 AM
WayneSS01's Avatar
You need a new hub assembly for that wheel.
Old Sep 20, 2008 | 11:05 AM
camaro468's Avatar
i am running 275s in the front i checked the tie rods ball joints for play
Old Sep 20, 2008 | 11:07 AM
camaro468's Avatar
does it whin i trun both ways your saying both sides are bad ?
Old Sep 20, 2008 | 08:44 PM
Jack the car up and grab the tire in the 12:00 and 6:00 position. Then try to rock the tire in and out. If it doesn't move, then you probably do not need new hubs.
Old Sep 22, 2008 | 06:43 PM
camaro468's Avatar
i am tinking it is in the rack couse you can feel it in the streeing wheel whin it does it i might be wrong though ill check what ya said too
Old Sep 23, 2008 | 09:14 AM
twitchtwice's Avatar
makes sure you torqued all your wheels lug nuts to 100ftlbs
Old Sep 23, 2008 | 11:24 AM
ryanater's Avatar
Easy... Your CV axle is going out
Old Sep 23, 2008 | 06:50 PM
camaro468's Avatar
dude are u kidden its a camaro ?
Old Sep 27, 2008 | 09:38 AM
WayneSS01's Avatar
My right front clicked when turning left. The faster it rotated the faster the click. Replaced the right front hub. No more clicking.
Old Sep 27, 2008 | 11:48 PM
defcon(ls)1's Avatar
I get a click under this circumstance:
1) I reverse out of my parking spot
2) I put into Drive and go forward.
3) The first time I hit the brakes, I hear a "click" (from the driver's side)
It doesn't happen afterwards until I repeat Step #1 and #2
Any more ideas???
