Strano Front Bar: First impressions
LS1TECH Sponsor
So, what it comes down to is figuring out what you mean by "more stable", but breaking down the car's actions and what you don't like about them and when (like what kind of input makes it happen). A front bar being bigger might help.
__________________
its a 98 z28 has a 9" and kyb agxs umi lower control arms, torque arm and sub frame connectors, and 245/50/16 tires at 34psi.
ill do a quick dodge the rock in the raod and the front feels planted, but the rear feels like there could be more control
LS1TECH Sponsor
Suspensions have many parts. Each works in conjunction with others, and one change breeds others. Bars are about body roll and balance. Shocks are about transition and stability. A bar change can warrant a shock change, and vice-versa but the basic jobs are different.
__________________
LS1TECH Sponsor
Z28/Forumula bar is 30mm, SS/WS6/1LE is 32mm. Mine is 35mm in front.
The Turbo kit you have is problematic. In fact I have a customer having this problem, but he also had it with the stock bar. In short, it's APS's issue if the piping won't even clear the front bar that is OEM on every car built.
__________________
LS1TECH Sponsor
The problem with shimming the bar down like they want to do is this: It puts the swaybar in closer proximity to the tie-rod end, and I have seen bars hit tie-rods and the tie-rod bends. In fact a shorter end-link will make this worse as you shim the bar down.
__________________
