best springs for autoX (not coil overs)
my car has koni double adjustables up front, singles in the rear. 1LE front sway bar, stock rear sway bar.
LG TA and LCA (poly/rod). i think the car handles awesome now, but i'd like to turn it up a notch. i autocross 3-4 times per month and theres this damn mustang i can't seem to beat.
i figure my two choices are:
-35mm solid front bar
-stiffer springs
i'd like to do one at a time, but which one should i do first? i like the bar because when i drag race, i can remove it completely and it won't hurt my ET. but the springs will hurt my ET because they restrict weight transfer. i don't drag race too often anymore, so i would get springs if they'd help the autoX.
i hear the rear springs are fine for autocross; can i just buy some front springs? i prefer not to lower the car too much. definately not over one inch. would like to keep it stock ride height if possible. 1LE front springs might be good for me or the SLP ones. don't know.
i need some hardcore autocrossers to give me advice on this topic. i'll open track 2-3 times per year if that makes a difference; that is just for fun.
-stiffer springs
Re: best springs for autoX (not coil overs)
Wouldn't upgrading your rear swaybar help you out both in autocross and maybe a little in drag racing?
